Hello Everyone First post here. I'm having a problem with my #1 cylinder coil wiring. With the key on, engine off, I have battery voltage at both the power wire and the signal wire at the coil connection. If I connect a coil pack and turn the ignition on/ engine off the coil gets so hot you can't touch it. I've tried 3 different PTU's. Also with the ECU to PTU connecter plugged up, ground from the PTU ohms very high to the PTU ground wire behind #6. When I unplug that one connection I do have great ground from the ECU. I have tested and tested for over 40hrs. If you have any idea what I should try or check, please advise me. At your convenience of course. I can't find anyone that has had this problem. This all started after I did my 120K maintance. Car was perfect before. Thanks Again! Tom Burns
